Activity › Forums › Adobe Premiere Pro › AJA Kona 3G audio issues
  • AJA Kona 3G audio issues
    Posted by Grayson Sedory on September 8, 2015 at 5:06 pm
    I’m wondering if there is anyone that can help with this issue. I’m currently using Premiere Pro CC 14.2 with a AJA Kona 3g card.
    I’ve been trying to find the correct settings but I have run into some issues with audio.
    Using
    Playback
    Audio Device – Kona3g-0 (checked) with use sequence settings in setup
    everything plays correctly except for WAV Files. They play slow and with a severe stutter until I put them into my 1080 24p or 720 59.94 timeline and then they play fine.
    I have to assume that this is because the Kona card isn’t able to conform to the sequence setting of the WAV file.
    Using a blackmagic card in another Edit suite works fine with the same settings.
    Anyone have any suggestions for a fix? My current work around is to throw all of my WAV tracks into a sequence and edit from it (not ideal).
    Thanks for the help!
    Grayson Sedory replied 11 years ago 1 Member · 0 Replies
  • 0 Replies
