Activity Forums AJA Video Systems AJA Kona 3G
  • AJA Kona 3G
    Posted by Aboud Orfali on February 27, 2013 at 7:53 am
    Dears;
    Greetings …
    I have the following setup :
  • Apple Mac Pro 2.4 Intel Xeon (12 Cores )with Final Cut Pro 7 installed
    AJA KONA 3G With BreakOut Box.
    SONY VTR .
    Panasonic HD Broadcast monitor.
    When trying to capture from the VTR machine (HD Camera image) on the final cut pro 7 I can not get any image i only hear sound even in the playback function (Connections are all correct and settings seems to be OK 1080/25i and the problem appears also when using the LCD Broadcast monitor .
    I tried several steps without any use .
    Please I need your help with this .
    Thank you for all your help & support.
Aboud Orfali replied 13 years, 6 months ago 2 Members · 2 Replies
    • Shane Ross
      March 1, 2013 at 7:53 pm
      Do you have your FCP Easy Setup chosen to match that frame rate and frame size? I’d use AJA Kona 3 1080i25 ProRes 422. Then make sure that the Frame Buffer in the AJA Control Panel is also set up for that frame size and rate.
      Shane
      Little Frog Post
    • Aboud Orfali
      March 3, 2013 at 10:48 am
      Thank you for your concern .. I had my problem fixed the problem was in the connection between my Break out Box and the PCie.
      Thank you
      Wish you all the best.
