Activity Forums AJA Video Systems aja kona 3 firmware
  • aja kona 3 firmware
    Posted by Jan Klonowski on May 31, 2013 at 7:17 pm
    hi guys,
    iv got an used kona 3 but got some problems unsing avid and scratch, mazze from the assimilate mentioned firmware update. unfortunatly i cant find any updater for this, i use driver version 10.3.2 on windows machine my actual fw is
    Hardware ID:
    KONA 3 (0x10196500) S/N 00B21950 K3-Box Breakout Box
    VideoProc Bit file:
    2011/05/11 15:26:35 DownConvert
    PCI Bit file:
    2011/05/11 15:26:35
    Driver Version:
    10.3.5 build 25 64bit
    can someone pls tell me if this is tha lattes firmware
    kind
    regards jan
    Kevin Christopher replied 13 years, 1 month ago 2 Members · 1 Reply
  • Kevin Christopher
    August 20, 2013 at 5:01 pm
    You have newer Firmware than I do, but older drivers. I run both mac and PC via boot camp. on the mac there is a firmware updating application. If memory serves me correctly on the PC side the driver loads the firmware on initialization. This is what allows AJA to upgrade the functionality of the card so easily.
    Kevin
