Activity › Forums › AJA Video Systems › AJA Ki Pro Hard Drive Replacement
  • AJA Ki Pro Hard Drive Replacement
    Posted by Rodney Kobayakawa on March 19, 2011 at 2:54 am
    I have a 250G module. Tried to replace the Hitachi 250G unit with a Seagate 500G/7200 rpm unit. Ki Pro does not recognize the drive (No Slot). Drive is spinning. Does AJA use a proprietary formatting process before shipping the drive?
    Chris Mueller replied 10 years, 8 months ago 9 Members · 11 Replies
  • 11 Replies
  • Jeremy Garchow
    March 19, 2011 at 2:56 am
    You should format any drives with the KiPro. This is an AJA drive, correct, not a do-it-yourself?
  • Rodney Kobayakawa
    March 19, 2011 at 4:52 am
    Its a do-it-yourself drive. I cracked the case and replaced the 250 stock drive with a Seagate 500G/7200 rpm drive.The Ki Pro does not see the drive. I put back the 250G drive and all is well.
  • Aja Sales department
    March 20, 2011 at 2:48 am
    Rodney,
    The use of unauthorized drives inside of the Ki Pro Storage Module is not recommended or warrantied. We would strongly discourage such activity. The drives contained inside of the Ki Pro Storage Modules have been selected for their specific attributes and thoroughly tested for use with the device. If you wish to obtain a 500GB Storage Module, AJA does offer that capacity and such a Storage Module can be obtained from an authorized AJA reseller.
    AJA Video Systems
    +1 (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • Jeremy Garchow
    March 20, 2011 at 3:27 pm
    [Rodney Kobayakawa] “Its a do-it-yourself drive. I cracked the case and replaced the 250 stock drive with a Seagate 500G/7200 rpm drive.The Ki Pro does not see the drive. I put back the 250G drive and all is well.
    Unfortunately it doesn’t work that way as the drives are not user replaceable. Time to go out and buy the AJA 500 GB storage module, it does exist.
  • Sylvain Sailler
    January 23, 2012 at 4:49 pm
    It’s possible to replace the internal hard drive. I’ve made it without any recording or reading issue. I used a fast 7200 rpm drive. You have to format it in Mac OS extended WITHOUT journaled option, in GUID Partition Table (use Mac Os 10.5 or 10.6 Disc Utility as 10.7 doesn’t allow to format in Mac OS extended NON journaled).
    https://www.atreid.com/index.html?menu=1223&id=4453&forum=5&sujet=50896&action=
  • Gary Adcock
    January 23, 2012 at 7:35 pm
    [Sylvain Sailler] “It’s possible to replace the internal hard drive.”
    There are No internal Drives in the KiPro.
    There is also no user certified method for swapping HD’s in the drive cases- doing this will VOID all warranties on the unit.
    gary
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Sylvain Sailler
    January 23, 2012 at 7:55 pm
    Sorry, by internal I meant inside the storage module.
    I know Aja doesn’t certify any method for this but it’s absolutely safe and easy to open the module and change the drive. Easy way to save at least 300 $ / 500 GB.
  • Tim Halle
    April 9, 2014 at 3:28 pm
    Confirmed this works April 9 2014.
    Does anyone know the KiPro to eSATA hack ?
  • Joris Robijn
    February 2, 2015 at 10:14 am
    Well, the connector on the AJA Ki Pro storage module is just a slimline SATA connector, just like on half-height DVD drives. I guess with a slimline SATA to eSATA converter you can connect it to Mac or PC. I connect via USB3, with a slimline SATA to USB3 converter. On the PC you will need software to use this NFS+ filesystem which is not normally supported by Windows. I use Paragon HFS+ for Windows for that. Works well.
    Joris
  • Chris Mueller
    February 25, 2015 at 8:39 pm
    Accessing the storage module to offload data can be accomplished using the 12V power supply and accessing the 7-pin data side on the slimline SATA connector.
    Recording from the KiPro directly to a SATA disk requires an active circuit. So there are no “over-the-counter” cable hacks, but there is an adapter available at https://didacco.com
