Activity › Forums › AJA Video Systems › AJA iOLA drivers/firmware
  • AJA iOLA drivers/firmware
    Posted by Ron Thompson on October 2, 2005 at 12:39 pm
    I just picked up a ioLA to use as a convertor box for my new KonaLH. The LH is working fine, but I can’t get the LA to work.
    What is the correct firmware and drivers? What is the current control panel software version? And how do I get the box into “stand-alone” mode?
    I thought this would be an option via the control panel, but I don’t see it.
    So I think I might have installed something incorrectly. I poured through the manuals and software options on the support site…just want to cross check here.
    Ron
    Christopher Wright replied 21 years ago 3 Members · 3 Replies
  • Ron Thompson
    October 2, 2005 at 12:41 pm
    ALSO…despite running video into the LA, and seeing that the LA “sees” the signal, the control panel still says “No Video.” Further proof that I think I might have done something wrong.
    Ron
  • Bob Zelin
    October 2, 2005 at 2:25 pm
    Boy, am I confused – why would you need an AJA I/O LA if you have the LH?
    It’s easy to get the drivers for your I/O LA. Go to http://www.aja.com, click on Support, click on IO support, and you will see the I/O LA drivers on the list. Click on that, and it will load onto your system. Restart, and go to EASY SETUPS, and select an I/O LA setting in Easy Setups, and you will be in business. But the LH does everything you need – why do you need the I/O LA anyway?
    Bob Zelin
  • Christopher Wright
    October 2, 2005 at 7:54 pm
    Well for one thing, he has an easy way to transcode any analog signal to SDI by using that set up. On the LA he has a “real” S-VHS connector I/O, and ditto for the the composite and component analog connections. With the LH, you get one component cable, which you can then configure separately to either be composite, component or S-VHS (which BTW requires a specialty dual bnc to s-vhs conversion cable). If you are in a studio that uses S-VHS material, composite, component, SDI, HD/SDI and HD component all with frequency, his set-up allows you to have everything connected and available for use at once, instead of having to change cabling I/O for every different source he uses, as is currently required by the LH. To answer your own question, he has the best of both worlds!
