Activity Forums AJA Video Systems Aja IOHD Simple question and a litle silly…
  • Aja IOHD Simple question and a litle silly…
    Posted by Nasos Karamo on February 13, 2008 at 4:45 pm
    Good afternoon,
    Im newbie here and i have some question…
    I try to make my own small post production studio you can say..I have started with a mac pro,apple cinema display,motu 828,FCS 2 and the latest buy Aja IOHD…And i test my workflow..
    I have some questions.
    I decide to test a workflow with prores for sd editing…Aja help me when i edit my pro res footage or only when i capture footage and i want to transcode to prores ? ? ?Im a bit confused as you can see..
    Thanks in advance
    p.s. sorry for my poor english,i m trying to improve them…
    Jeremy Garchow replied 18 years, 6 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    February 13, 2008 at 6:26 pm
    With the ioHD, you can capture whatever footage you have to ProRes (or any other SD codec). In HD you should work with ProRes.
    If you have ProRes footage, the ioHD will play it out, along with any other SD codec without transcoding.
    Does that help?
    Jeremy
  • Nasos Karamo
    February 13, 2008 at 9:14 pm
    Ok but im wondering when i start editing sd footage-prores for a start is going to make a difference if i have power on iohd or not ? ?
    Be patient with my english 🙂
  • Jeremy Garchow
    February 13, 2008 at 9:19 pm
    If you do not have power to the ioHD, you will not be able to monitor your ProRes footage.
  • Nasos Karamo
    February 13, 2008 at 9:36 pm
    For a start cause i make only tests and not “real” editings i wonder if iohd helps my mac lets say with the processor power ? ?There is a difference if i edit with plug in iohd as concerns the “power” and the “speed” of my machine in the editing ? ? ?
    To monitor my footage except my display is for me an other issue 😉
  • Jeremy Garchow
    February 13, 2008 at 9:50 pm
    No. the ioHD does not accelrate your machine.
  • Nasos Karamo
    February 13, 2008 at 9:55 pm
    OOOOOOk thanks alot
  • David Skillicorn
    February 15, 2008 at 3:53 am
    I just bought this unit too and will use with MacPro and Caldigit Raid. My assumption was that once the ProRes codec files are on the hard drive…. I could view them in FCP through direct DVI connection to computer monitors if I wanted, whether or not the IOHD was on…. or I could loop through IOHD to any monitoring situation…. but if I wanted to just go with computer monitors…. I would be able to do that without the IOHD.
    Is this not correct?
  • Jeremy Garchow
    February 15, 2008 at 4:20 pm
    You can use the digital cinema desktop preview in FCP. It’s highly inaccurate and takes up one of your screens, but it’s doable.
    Jeremy
