Activity › Forums › AJA Video Systems › AJA Io with Gtech G-RAID and 10bit
  • AJA Io with Gtech G-RAID and 10bit
    Posted by Michael on April 6, 2005 at 8:16 am
    I have Apple G5dual 2.5G + 2Gb
    I Use AJA Io and G-RAID 2/500 (FW800)
    When i capture 10bit uncopressed (SDI to 10bit) i have drop frame, but when i capture to internal disk – all ok and when i capture 8bit to G-Raid it’s Ok too.
    MAC OSX – 10.3.8
    QT – 6.5.2
    AJA Io – 1.3.1 (FW21-26)
    Dave Jenkins replied 21 years, 5 months ago 4 Members · 5 Replies
  • Bob Zelin
    April 6, 2005 at 6:45 pm
    I am not surprised by your results. These are just Firewire800 drives, just like the Lacie. They do 8 bit uncompressed (which is fine for “broadcast quality”), and DVCPro50 and DVCProHD.
    Be happy – it’s cheap.
    bob Zelin
  • Miha_pece
    April 7, 2005 at 8:47 am
    Go on g-tech forum on cow and you will get more answers. I’m usin g-raid with 8-bit without problems. I only tested 10 bit for shorh clip and I didn’t had drop frames. I would try longer capture, but now we are full until summer, so i cannot help you. As i sad, check on g-tech and Medea forum.
    Miha
  • Dave Jenkins
    April 10, 2005 at 6:24 am
    Are you using the internal FW 800 port or a PCI FW 800 card?
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO
    Huge 1.2 Raid
    FCP 4.5-OS X 10.3.5-QT 6.5
  • Michael
    April 11, 2005 at 10:04 am
    Internal
  • Dave Jenkins
    April 12, 2005 at 6:18 pm
    The AJA IO uses all the FW and from what I have been told the 400 & 800 FW buses on the G5’s is shared. You should use a PCI card.
    Dajen Productions
    Santa Barbara, CA
    Huge 1.2 Raid
