Activity › Forums › AJA Video Systems › Aja io vs io HD
  • Aja io vs io HD
    Posted by Dave Nadal on March 7, 2008 at 12:50 am
    Hello, I have a reduced budget, and I see that AJA io and aja io HD are more similar. HD have a prores422 compression but with io model I think that I will capture with normal resolution of my panasonic ( DVCPRO HD ) and compress with FInal cut pro 6. Is it correct? The quality of compression is the same of ioHD ? for reduced price do you recomment IO version or ioHD has more quality ad da and options ? Thanks and greetings
    John Pale replied 18 years, 6 months ago 2 Members · 1 Reply
  • John Pale
    March 13, 2008 at 4:30 am
    The standard iO does not work with HD. Standard def only….so no DVCPRO HD
