Activity Forums AJA Video Systems AJA io V.S. Black Magic Design Multi Bridge Eclipse
  • AJA io V.S. Black Magic Design Multi Bridge Eclipse
    Posted by Micah Wolf on December 4, 2008 at 5:03 pm
    Can any one tell me the + and – between the AJA io over Black Magic Multi Bridge Eclipse.
    I will be running Adobe CS3 on Leapord.
    Any info would be great.
    Thank You
    Micah
    Matthew Causon replied 17 years, 9 months ago 4 Members · 6 Replies
  • Carsten Orlt
    December 4, 2008 at 8:15 pm
    If you would make the effort to check the system requirements on the Aja website you would see that the Aja IO range is Final Cut only . . .
    Carsten
  • Micah Wolf
    December 4, 2008 at 8:23 pm
    But it does work with After Effects which is an adobe product. So will it work with Premier Pro as well and for the record I have but in effort in looking into these two products no reason to be short Carsten
  • Carsten Orlt
    December 4, 2008 at 9:35 pm
    io doesn’t work with Premiere Pro.
    and yes sorry for being short. 🙂
  • Micah Wolf
    December 4, 2008 at 9:49 pm
    Thank you
  • Gary Adcock
    December 5, 2008 at 2:08 pm
    [Micah Wolf] “So will it work with Premier Pro as well and for the record I have but in effort in looking into these two products no reason to be short Carsten”
    nope
    sorry but it will not work with Premier…
    carsten is correct.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Matthew Causon
    December 6, 2008 at 12:24 am
    Hello Micah
    Whilst the AJA Io range are FCP based product, the AJA Kona cards (Mac) and Xena cards (PC) both work with Adobe Premier so you perhaps should consider compare those with the MultiBridge?
    What’s more you could say the Kona/Xena range are more comparable to the MultiBridge as they are also PCI/PCIe based cards designed for working with Desktop computer.
    The Io range are designed principally to work with Laptop computers (Mac). The Multibridge does not.
    If you do some searches you should find many strings regarding the many pros and pros of using Kona/Xena product over the Multibridge. But if you need some assistance let us know.
    Best regards
    Matthew Causon
    AMP Europe
