Activity › Forums › AJA Video Systems › AJA I/O possible failing
  • AJA I/O possible failing
    Posted by Mikeslee on June 13, 2006 at 8:59 pm
    I have a G-5 dual 2 gig. I’m using a 900 gig Huge system drive SCSI Atto 4-card and a AJA I/O. I have not installed Final Cut Pro 5.1 yet. I am in the middle of two edits and don’t want to genix them.
    I just started having a (disconnect problem) with the NTSC monitor. While playing either source or timeline the program monitor (out of AJA) will go black and the video will freeze. Ten seconds later the spinning beach ball of hell comes on. I have lost control of the program, basically locks up. I have to force quit to get anything working again. After throughing away the preferences I try to launch the program and I get a (error code -600). It is still shoping a non-responce in the funder. I have to shut down and rester to get the program to luach. What is a (error code -600)
    I have tried running the program without the aja and it seems to be working but the audio sucks. Any idea what might be causing the failure and how to fix it?
    Thaknk you for your help.
    Mike
    Zaragoza Pictures, Inc.
    http://www.zaragozapictures.com
    Bob Zelin replied 20 years, 3 months ago 2 Members · 1 Reply
  • Bob Zelin
    June 14, 2006 at 2:17 am
    repair permissions, trash your preferences (all of them), uninstall and reinistall the AJA I/O drivers.
    When all of this is done, test your AJA I/O using the AJA Pro I/O control panel instead of FCP, to see if it is working ok. As a matter of fact, before you do any of the software stuff, use the Pro I/O control panel to
    test your I/O. I bet the software stuff fixes it.
    bob Zelin
