Activity Forums AJA Video Systems Aja Io La Offline RT problem / Genlock PAL
  • Aja Io La Offline RT problem / Genlock PAL
    Posted by Axel Ebermann on July 9, 2005 at 10:34 pm
    I just got an AJA Io La. Installation went fine, I can digitize
    – except there is no YUV to Offline RT Pal codec in the drop down list….
    There is only a YUV PAL to Offline RT NTSC conversion option.
    Any advice ?
    Plus: The unit always seems to be in NTSC default – how do I chnage that ?
    Axel
    Axel Ebermann replied 21 years, 1 month ago 2 Members · 2 Replies
  • Aja Sales department
    July 9, 2005 at 11:59 pm
    Hi-
    Inside of the Io installer, is one named “IoLA-PAL.mpkg”. Is this what you installed? It should contain the PAL setups you need.
    Thank you,
    AJA Video Systems
    (530) 274-2048 Intl.
    (800) 251-4224 US
    sales@aja.com
  • Axel Ebermann
    July 10, 2005 at 4:47 am
    I installed that and it does not give me remotely as many options as I have in NTSC.
    I even downloaded the newest codec pack from AJA.
    I only get the following component codecs:
    PAL Uncompressed 10bit
    PAL Uncompressed 8 bit
    Component to DV Pal
    Component to Offline NTSC (very strange, because it must convert the video stream to NTSC)
    There is no component pal to offline PAL (photo jpeg) option
