Activity Forums AJA Video Systems AJA IO HD – “device offline” in control panel – help
  • AJA IO HD – “device offline” in control panel – help
    Posted by David Reppond on April 19, 2009 at 7:34 pm
    Hi Everyone – My AJA IO HD unit is coming up as “device offline” in the control panel…..not sure what’s happening because i downloaded recent version 6.0.3
    any help would be really appreciated. i’m under a deadline and this thing is driving me crazy 🙂
    Kent Stipp replied 17 years, 5 months ago 5 Members · 5 Replies
  • Carsten Orlt
    April 20, 2009 at 5:07 am
    I never had that problem so the following is just a thought..
    Can it be that the ioHD wasn’t connected at the time you updated the drivers?
    Maybe, with the ioHD connected, try re-installing the software again and make sure the io updater finishes burning the software to the ioHD as well!
    If you done all that already The only other thing I could think of is a faulty cable, a faulty ioHD, other devices on the firewire bus…
    You might have to cal Aja.
    Carsten
  • Jeff Mack
    April 20, 2009 at 3:28 pm
    Try turning off and then back on.
    Jeff
  • Jeremy Garchow
    April 26, 2009 at 12:36 am
    Restart?
  • Jeff Mack
    April 26, 2009 at 12:39 am
    This has happened when I connect out of order. I turn off the IOHD (switch on the back) and it comes online.
    Jeff
  • Kent Stipp
    April 27, 2009 at 8:08 pm
    I know that some people have had an issue with the latest drivers and needed to go back one rev. The only other thing I can think of is make sure the IoHD is powered on before restarting the computer
    Kent Stipp
    Life Begins at 155mph
    Ki PRO Lens to Post
    3am Studios llc.
    3amstudios.org
    Sharedsummitsfever.com
