Activity Forums AJA Video Systems Aja Io hd and xl-h1
  • Aja Io hd and xl-h1
    Posted by Andrea De paula on October 2, 2008 at 3:30 pm
    Hi. I am about to record a concert with 4 cameras. One of them is a XL-H1 and we are planning to capture the footage with aja io hd. The cameras will shoot at 24F. When we connect aja io hd to the XL-H1, aja doesn’t read 23.98 nor 24p. It reads 29.97i – is that correct? What’s the best workflow to capture the footage and deliver it in true 24p?
    Thanks a lot.
    – Andrea
    Andrea De paula replied 17 years, 7 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    October 2, 2008 at 4:02 pm
    I do not think the XL-H1 outputs a 23.98 signal only 60i (24psf with pulldown). You have to capture 1080i. This is a limiation of the camera.
    Jeremy
  • Jesus Ali
    October 4, 2008 at 9:47 am
    Andrea, what connectors are you using to connect the XL-H1?
    We have the same camera, but I haven’t played capturing 24p with the IoHD.
    Jeremy is right, the XL-H1’s 24F (note the “F”, not a “p”) mode is based on video tape pulldown patterns, and on top of that, it is a proprietary method. Tapes recorded in 24F on this camera won’t play in anything except the newest Sony HDV deck or a Canon HV10 or HV20.
    If you were playing back the TAPE from the camera I agree completely with Jeremy’s advice.
    But shooting live, I wonder if the 24F is even applied to the output signal. I know that the signal is output from the HD-SDI port BEFORE HDV compression is applied, so I wonder if the pull down hints (which are used specifically for recording to tape) are even included in the output HD-SDI signal.
    Does anyone know about this specifically?
  • Andrea De paula
    October 4, 2008 at 2:43 pm
    Hi Jesus!
    Here is the answer I got from Aja:
    Andrea:
    The XLH-1 will always output 29.97 via the HD-SDI output.
    The IOHD is auto detecting the correct format. There is now way around this if you capture with the IOHD. You will have to use 29.97
    The only way to output 24 frame out of that camera is via Firewire.
    Regards,
    Gerald
    Gerald Kaczorowski
    AJA Video Technical Support
    So, the 24F signal is applied just to the tape.
    – Andrea
