Activity Forums AJA Video Systems AJA Io HD 10.3.2 compatibility
  • AJA Io HD 10.3.2 compatibility
    Posted by Jim Turney on May 16, 2020 at 5:05 am
    I bought an AJA Io HD encoder for digitizing SD analog videotapes with my Mac mini late 2012.
    What’s the last version of OSX that works with the Io HD 10.3.2 driver and control panel?
    I’ve tried installing on 10.11 but it’s not compatible. Is 10.8 the only version compatible?
    And, does anyone know if OBS will work with AJA Io HD? I know Io HD was designed to work with FCP but all the encoding is done by the hardware and delivered to the Mac via FW800 so is there other software that can capture the data from the Io HD?
    https://www.aja.com/products/io-hd
    https://obsproject.com/
    Jim Turney replied 6 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
