Activity Forums AJA Video Systems AJA Io Final Cut 5, Dropping Frames
  • AJA Io Final Cut 5, Dropping Frames
    Posted by Jus10case on June 20, 2006 at 4:23 pm
    OK here is the long and drawn out problem I am having.
    I have a Dual G5 1.8, with 1.25GB of RAM. 80GB OS Drive, running OSX 10.3.9. AJA Io running the 2.1 driver (tried the 3 driver, but it seemed really flaky)
    There is a 2nd SATA 200GB (ST3200822AS)internal drive that I have been capturing to for 8 months with no problem at SDI 10Bit Uncompressed from my digibeta deck. I pulled that 200GB drive and replaced it with a 500GB 7200 16MB Cache Segate (ST3500641AS). With the 500GB drive it immediatly started dropping frames on capture. So I benchmarked the drives and the 500GB was a MB or two slower than the 200GB so I bought another 500GB drive and Raid 0’d them together using the SwiftData 200 kit from transintl.com. This config tests out at about 90MB/sec read, and over 100MB/sec write, and still I get the dropped frames problem. Can anyone help? Please? I am starting to have to capture 128Min at a time and the 200GB drive just isn’t large enough to hold it.
    Tony! Hulette replied 20 years, 2 months ago 4 Members · 15 Replies
  • 15 Replies
  • Marcray
    June 20, 2006 at 8:28 pm
    I too am having this same problem but with a macbook using an extermal sata enclosure with 2 drives. My system benchmarks at 120MB but still drops frames.
  • Jus10case
    June 20, 2006 at 8:38 pm
    I talked with a guy at AJA today, and he wants to think that it’s just physically something about the drives causing it. I’m not so sure I buy into that though since they are the same brand/speed as my 200GB single drive, that tests at like 40MB/sec and captures perfectly at 10bit uncompressed. And yet I have seen stranger. 🙂
  • Tony! Hulette
    My first thought is that you need to make sure you format the drives as “Mac OS Extended” not “Mac OS Extended Journaled”
    Next, I would follow the recommendations of AJA as follows:
    Q: I
  • Jus10case
    June 20, 2006 at 8:54 pm
    Yea I DID have them as Journaled before (and my 200GB drive that works perfectly is currenlty Journaled) but I did correct that the other day per the AJA “support” site, as well as try several other of their suggestions. I was on the phone with a tech person at AJA today, and they actually pointed me to this site as a place to see if anyone had any suggestions on ways to fix it.
  • Marcray
    June 20, 2006 at 10:03 pm
    Tony,
    I have gone through all the reccomendations aja has to offer including calling tech support. Also the drives are not journled but just formatted Mac OS Extended. I think I forgot to mention but the problem only seems to be during capture as I can playback from the timeline fine. I just ran another benchmark using the Kona test suite and it does show some fluctuations down to 80mb per second during write tests. Do you think 2 striped sata drives should work if I put this on a g5? I do not have a sata card in my g5 so I would need to purchase one, but hate to put any more money into the situation if I am not at least somewhat sure it will work:) Any help would be appreciated.
    Marc
  • Marcray
    June 20, 2006 at 10:05 pm
    Which program are you using to benchmark the drives? If you are using the kona test suite you may want to check the graph for random drops in the write speed.
    Marc
  • Bob Zelin
    June 21, 2006 at 10:53 pm
    you have not said what resolution you are working at – DV25, or 10 bit uncompressed SDI – or something in between ? If you are using 8 and 10 bit SDI uncompressed, or DVCProHD, you will never get reliable results with one single drive. I urge you to use an external SATA host controller card (like the firmtek or Sonnet), and TWO SATA drives that are stripped togeher RAID 0. You will easily get 120mb/sec speeds, which will do 8 and 10 bit SDI uncomrpessed with no dropped frames. One SATA drive will do nothing for you reliably.
    Bob Zelin
  • Jus10case
    June 21, 2006 at 10:58 pm
    I was trying 10bit uncompressed from the DigiBeta. I have a firmtek internal SATA card with two 500GB Seagate drives Stipped Raid 0. It’s a kit from Transintl.com that allows you to mount up to 3 more internal drives in the G5’s. It’s avg around 100mb/sec according to the kona test thing from aja. I also looked at the graph and text from that test and it does slighly fluctuate, but never more than 10mb/sec or so.
  • Jus10case
    June 23, 2006 at 6:42 pm
    The other strange thing about it, is that I can move the media from my 200GB single drive to the two raid 0 500GB drives and edit 10bit uncompressed with no frame drops at all, but still it drops during capture.
  • Bob Zelin
    June 24, 2006 at 10:01 pm
    just10case writes –
    REPLY – this is not strange. when you move media onto your 500 gig drives, the READ SPEED is faster than the WRITE SPEED. If you simply run AJA Kona System test, you will see that the read speed of your 500 Gig drives is faster than the write speed (it’s all right in front of you on the display). If you would like to persue this further, please list EXACTLY what SATA host card you have, and EXACTLY what SATA drives you are using.
    I find it very hard to believe that you are able to CONSISTANTLY do an entire editing job at 10 bit uncompressed SDI off of one single 200 Gig drive. There is a big difference between doing a simple capture and playback, and actually editing, and asking the drive to search all over the place for material.
    Bob Zelin
