Activity › Forums › AJA Video Systems › AJA IO, FCP 5, and DVCPRO930 Deck RS422
  • AJA IO, FCP 5, and DVCPRO930 Deck RS422
    Posted by Greg Kadonada on May 26, 2006 at 3:52 pm
    Has anyone successfully been able to “edit to tape” via RS 422 and the AJSD930?
    Ironically, I was able to black and code with the Sony machine control instruction set, but couldnt get the deck to respond going into record with assemble mode.
    I was not able to get the Panasonic machine control set to talk to the deck AT ALL for anything!
    Help! 🙂
    Much thanks in advance.
    Shadowgk
    Editor/graphics
    Greg Kadonada replied 20 years, 4 months ago 2 Members · 2 Replies
  • Jason Kalinoski
    May 30, 2006 at 7:42 pm
    It’s been a long time since I dealt with this, but I’m pretty sure the problem
    is the frame offset that you need to set for the IO. (5 frames?)
    Use the Panasonice deck setup, but change your playback offset to zero. The canvas and
    output will be out of sync, but it will lay to tape fine.
    I’m not in front of our system right now, but I think this was the ultimate solution. We also
    use a 930 deck…
    Jason
  • Greg Kadonada
    May 30, 2006 at 11:35 pm
    Thank you. Ill try that.
    Shadowgk
    Editor/graphics
