Activity › Forums › AJA Video Systems › AJA IO dsr-11 firewire trouble
Posted by Coxanadu on October 9, 2005 at 9:17 pmTwo things: Is my new AJA IO the reason I can no longer plug my DCR-11 DVCAM direct into my mac? I get the classic no device is plugged in warning, it doesn’t see it. My next question is now that I have the IO is deck control possible with a DSR-11? Or did I lose that capability when I got the IO. And uninstalling AJA did nothing. Answers would be very helpful. Thank you.
Lee Berger replied 20 years, 11 months ago 3 Members · 4 Replies -
Lee Berger
October 10, 2005 at 10:45 pmYou cannot have both the Io and a firewire device such as your DSR 11 hooked up to the firewire bus same time (including PCI cards). This is covered in AJA’s Io FAQ on their website https://www.aja.com/support_Io.html#faq at the bottom of the page. They recommend an A/B firewire switch available at https://www.signvideo.com/firewire-switch-ieee-1394.htm or an expensive firewire port selector( however the manufacturer no longer offers the device they link to). I have the A/B switch and it works fairly well, but you have to exit FCP to make the switch or it may cause a crash. Also you have to be sure the connectors are firmly seated or FCP won’t see the switch.
Lee
Lee Berger
October 10, 2005 at 10:56 pmI also forgot to add that if you choose the A/B switch the total firewire cable length cannot exceed 15 feet between your Mac and the Io or DSR 11. The switch counts for at least one foot. I use an 8′ cable between the Mac and switch, and 3′ cable between the switch, Io, and my DSR1500.
I capture my DVCam material via firewire and then switch back to the Io for monitoring. It becomes a pain when you need to capture something in the middle of editing. You have to switch to the DV Easy Setting, Exit FCP, switch the A/B switch to the deck, open FCP and capture. Then you have to do the whole thing in reverse to use the Io. Dooable, but not very elegant.
Mitch Ives
October 20, 2005 at 4:31 pm[Lee Berger] “I use an 8′ cable between the Mac and switch, and 3′ cable between the switch, Io, and my DSR1500. “
If you have a 1500 why would you bother with a DSR-11? Add the SDI option to your 1500 and your world will forever change, as your DVcam footage will improve imeasurably…
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.com
http://www.insightproductions.com -
Lee Berger
October 20, 2005 at 7:06 pmI never said that I have a DSR 11. I have the 1500, however the firewire issue is the same for both decks when capturing DV via firewire. The SDI option is a great idea, however it’s expensive. I put my money into the Analog option, however I have many projects that are fine in DV so I capture DV via firewire and then use the Io for monitoring and output to Betacam.
