Activity › Forums › AJA Video Systems › :: AJA io connect to TV LOGIC , monitor::
  • :: AJA io connect to TV LOGIC , monitor::
    Posted by Martha Poly r. mendivil on January 28, 2011 at 6:26 pm
    Hello!
    WE’re trying to connect a FCP project to display on a TV Logic Monitor through an AJA io using SDI output and SDI input on the Tv Logic. We’ve been switching around the settings in order to get the image displayed correctly in our Tv Logic. The timeline settings are AppleProRes 4444 1920×1080 running at 23.98fps.
    Even if we try different settings of video playback we get the same interlaced image on the TV Logic which doesn’t match the look of the project’s image.
    Any ideas?
    Martha Poly R, Mendivil
    PostProduction Assistant
    El Barandal PostProduction
    Mexico City
    Jeremy Garchow replied 15 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 28, 2011 at 10:38 pm
    The original AJA io is SD only.
    The ioHD does not do ProRes 4444.
    You will need a Kona card for this, or work in a ProRes422 timeline.
    Jeremy
