Activity Forums AJA Video Systems AJA iO and QT problems
  • AJA iO and QT problems
    Posted by Brett Cantrell on October 7, 2005 at 1:55 pm
    This sounds kinda similar to some other posts about camera recognition, but not exactly and all of the mentioned fixes don’t seem to work.
    When I try to open the log and capture window in FCP i get a message explaining that an error occured while configuring QT using my current capture preset.
    I am coming from a digibeta deck into an AJA iO box, a hardware connection i use all the time.
    I have two g5s here side by side and if I transfer the AJA connection over to the other system no problem, but on my system i always get this error.
    I have reinstalled QT 7.0.1, and can capture via firewire from other decks.
    please help, if i can’t capture video my computer is virtually worthless
    Jeremy Garchow replied 20 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    October 7, 2005 at 2:00 pm
    Are you sure you have the io drivers installed on the ‘bad’ machine? If not, uninstall then reinstall.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
