Activity Forums AJA Video Systems AJA Io and 23.98
  • AJA Io and 23.98
    Posted by David Massachi on June 16, 2005 at 11:58 pm
    Is anyone using the Io to edit in 23.98 timelines? Either DV or UN8 codec? Are you able to capture with on-the-fly 2:3 pulldown removal? Are you able to output while adding 2:3 pulldown on the fly?
    What is your system setup? What deck are you using and how do you control the deck?
    When I output to tape, I can only get a minute or 2 into the output before my deck just stops recording. The sequence continues to play until the end, but the deck just stops at 01:02:02:28.
    For another sequence I tried, it also stops during the output, but at a different timecode.
    Any suggestions about how to accomplish 23.98 editing with the Io?
    My system:
    Dual G4 1.42 GHz
    2 GB RAM
    OS 10.3.9
    FCP 4.5
    QT Pro 6.5.2
    QT Non-Pro 7.0.1
    Compressor 1.2.1
    Xserve RAID Driver 1.0
    RAID Admin 1.3.3
    RAID Firmware version 1.3.2/1.26a
    AJA Io with Driver v2.0b3 and Firmware Update v22-27
    Uncompressed 8-bit 4:2:2 via SDI to/from DVW-A500
    RS-422 deck control via Stealth Serial Port
    massachi
    David Massachi replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
