Activity › Forums › AJA Video Systems › AJA Hi5 3G vs. AJA HDP2
Jeremy Garchow
August 2, 2010 at 5:11 pm -
Sean Kapleton
August 2, 2010 at 5:58 pmhey great thanks for the pic just have a few questions
1) I have my blacks set 126 you had you thought yours was 125 – i just barely see the grey pluge so I am pretty sure this is correct – any thoughts?
2) luminance / brightness is 120 / 6500k whitepoint
3) Raster – why do you have this set to native?
4) you mention sometimes switching frame rights and SD but I thought the whole point of this box is that it would be able to properly detect and do this automatically – what am I missing?
thank you
sean
Jeremy Garchow
August 2, 2010 at 6:03 pm[Sean Kapleton] “1) I have my blacks set 126 you had you thought yours was 125 – i just barely see the grey pluge so I am pretty sure this is correct – any thoughts?”
On my monitor it goes to 125, but you need to set it to whatever looks best on yours. They might not necessarily match.
[Sean Kapleton] “2) luminance / brightness is 120 / 6500k whitepoint”
Brightness is relative toy our room, turn it up or down to your liking, 65K whitepoint, yes.
[Sean Kapleton] “3) Raster – why do you have this set to native?”
Native to the Dreamcolor. That way the monitor doesn’t do any scaling, only the HDP2.
[Sean Kapleton] “4) you mention sometimes switching frame rights and SD but I thought the whole point of this box is that it would be able to properly detect and do this automatically – what am I missing?”
You aren’t missing anything and the HDP2 will most likely output 60Hz (as that’s where the monitor looks the smoothest when monitoring NTSC flavor video). I sometimes switch to monitor 24p video in 48Hz instead of 60Hz. It’s a personal preference, leaving it in auto will be fine.
Sean Kapleton
August 2, 2010 at 7:18 pmbrilliant much thanks!
ps. have you or anyone else tried the HDLINK Pro 3D and if so what are your thoughts on this? I previously used the HDLINK Pro which was limited to 8bit but what I found annoying besides the flickering when switching between HD & SD and various frame rates (possibly could be a Dreamcolor issue requiring firmware update?) was the fact that the HDLINK had a utility window not unlike the HDP2 which had tabs with different adjusters (1D RGB output, etc) which actually did need to be tweaked accordingly to get the right calibration.
Jeremy Garchow
August 2, 2010 at 8:01 pm[Sean Kapleton] “have you or anyone else tried the HDLINK Pro 3D and if so what are your thoughts on this?”
I haven’t, sorry.
