Activity › Forums › AJA Video Systems › AJA HD Codec
AJA HD Codec
Posted by Vance on July 19, 2006 at 12:10 amI will be using a FCP system with a Kona 3 card this fall on a sports tour. The editor I am working with is anxious to work with the Kona Codec, while I am leaning to DVCPro100. We will be cutting 1080i footage. One of the devices we interface with, a server, is capable of providing the DVCPro material, but not Kona.
Is there somewhere I can find documentation comparing these codecs, or a white paper on the AJA Kona codecs?
Thanks-
-VanceTom Meegan replied 18 years, 9 months ago 7 Members · 19 Replies -
Gary Adcock
July 19, 2006 at 12:53 am[Vance Piccin] “We will be cutting 1080i footage. One of the devices we interface with, a server, is capable of providing the DVCPro material, but not Kona”
Vance I do not understand
if you are talking about EVS- it captures an industry standard DVCPROHD which can be read by FCP
AJA only supplies custom codecs for AE workflows
But DVCPROHD is a Panasonic Standard codec and is usable within FCP by the Kona cards.
What ever the HD format you are working in – the HDSDI can be converted on the fly by your Kona 3 to DVCPROHD without issue.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Chicago, IL -
Vance
July 19, 2006 at 1:12 amGary-
Thanks for the reply. The EVS is the device that I am talking about. There are two ways to gather material into FCP. The “easy” way is to play a clip on the EVS and just do a capture now. That is what my partner is now doing, using what he describes as either the “Kona” or “AJA” codec. Does the Kona card install additional codecs in FCP?
The alternate is to use the EVS hardware to transcode it’s material to DVCPro clips, then network the clips to the FCP system. I would like to experiment with this workflow. The problem here is the DVCPro material is pretty heavily compressed. That is fine for stuff comming from the EVS, but a little harsh for our other (graphic) elements.
In any event, I am curious to find information on the data rates and compression type of the Codec my partner is discussing.
-V
Gary Adcock
July 19, 2006 at 1:46 am[Vance Piccin] “That is what my partner is now doing, using what he describes as either the “Kona” or “AJA” codec. Does the Kona card install additional codecs in FCP?”
My guess is that he is not working in one of the custom Aja codecs- The are custom to specific workflows, and I have never heard of these Uncompressed 8 and 10bit animation codecs being used in broadcast.
[Vance Piccin] “The alternate is to use the EVS hardware to transcode it’s material to DVCPro clips, then network the clips to the FCP system.”
This is exactly the way that FOX did the ALCS and World Series the last 2 years, not to mention the Superbowl, the Daytona 500 and Nascar every weekend.[Vance Piccin] “The problem here is the DVCPro material is pretty heavily compressed. That is fine for stuff comming from the EVS, but a little harsh for our other (graphic) elements.”
Well do you want to be able to play in realtime or do you want to render. I was talking to Tom Meegan from Woven Pixels today at the C4 sports show and confirmed that he is in fact using DVCPROHD for all of his graphics during the World Series for the last 2 years.
gary adcock
Studio37
Chicago, IL -
Vance
July 19, 2006 at 2:08 am—>I was talking to Tom Meegan from Woven Pixels today at the C4 sports show and confirmed that he is in fact using DVCPROHD for all of his graphics during the World Series for the last 2 years.
I do think that we would be OK working in the DVC Pro codec. As our work will be feed back into an EVS before it goes to air, it is going to be stepped on anyway.
—>This is exactly the way that FOX did the ALCS and World Series the last 2 years, not to mention the Superbowl, the Daytona 500 and Nascar every weekend.
As for the Superbowls, I have done the last 6 in one capacity or another, and I have yet to see FCP interfaced to the EVS at the network level. In HD it has not been possible until recently to have the EVS transcode to HD QT format. Everything I have seen has been transfered baseband.
-Vance
Walter Biscardi
July 19, 2006 at 11:59 am[Vance Piccin] “The problem here is the DVCPro material is pretty heavily compressed. That is fine for stuff comming from the EVS, but a little harsh for our other (graphic) elements.”
Actually, we work in the DVCPro HD codec all day, every day for HD Network broadcast and it’s comopletely pristine for creating motion graphics and animations.
We create 30 – 60 second animations and motion graphics for the episodes and graphics is one of the areas where I find DVCPro HD indistiguishable from 8 or 10 bit uncompressed HD.
In addition, we ingest and edit all of our episodes in the DVCPro HD codec. It’s extremely clean.
Walter Biscardi, Jr.
https://www.biscardicreative.com“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Vance
July 20, 2006 at 2:03 amThanks Walter. I have never had a problem using DVCPro 100, tho I have always used it at 720p. I have yet to see it with 1080i footage, but I can’t imagine it would be much different.
My partner does most of the graphics work, and really perfers not to compress till the last possible moment. As the fill the donut guy, most of my source footage is already in some contribution codec anyway. My workflow and storage would be much easier in the DVC codec, but I am not sure I can sell him.
-Vnace
Tom Meegan
July 20, 2006 at 9:24 pmHi Vance,
You and I worked together on the Final Four this year. Hans Waters introduced us.
DVCProHD 720p is indeed what we used on the World Series inside FCP. Also from what I understand, this is what was done on the FCP systems for the Super Bowl in 2005. I used the FOX NASCAR system on the MLB All-Star game in Pittsburg, and it was set up for DVCProHD, so I assume those guys are using it that way as well.
In all the live, editing during the game, applications I’ve seen, it has always been baseband video in through the card of choice, either Kona 2, Kona LH, Kona LHe, or a Black Magic Design card (I’m not as familiar with their product line.) I talked a bit with the EVS guys about the MediaXchange product. It is still not quite there for FCP. I would talk to them directly if you want to go this way. It sounds like this will happen eventually, and the more of us who ask, the better I think.
I can certainly understand your partners reluctance to add another layer of compression.
Both Ryan Leimbach (Sunday Night Football) and Jim Dove (Sunday Night Baseball) are capturing uncompressed 10-bit via HD SDI (baseband video from the router) for their EVS to FCP transfers. Both are using AJA boards now, although, Jim previously was using Black Magic Design.
Contact me if you would like to get in touch with Jim or Ryan.
I hope you are doing well.
Tom Meegan
tom@wovenpixels.com -
Vance
July 20, 2006 at 10:48 pmHi Tom-
I spoke with Hans the other day. He was on his way to boating around Tampa Bay.
As I said in my offline reply, I am comming to understand that what my partner is talking about is an FCP setting using the Kona card to capture uncompressed rather than a compression codec. I will have to do some expermenting to see if there is any visual difference if I compress his elements to DVCPro to work with the game footage, or up rez the game footage to work uncompressed. If the difference is not noticable there are obviously a lot of advantages to working in the DVC coded.
-V
Tony
July 21, 2006 at 3:32 amJust because one compressed codec is acceptable for some does not imply it should be acceptable for others just because the “big boys” use it.
just my two cents.
Tony Salgado
Tom Meegan
July 21, 2006 at 10:41 amHi Vance,
You are probably aware of this site, but just in case…
https://codecs.onerivermedia.com/
Click codec resources and explore away. It is a pretty comprehensive look at codecs, and combines a good mix of the technical and the subjective.
Best of luck this fall!
Tom
