Activity Forums Adobe Premiere Pro Aja has new plugins for Creative Cloud
  • Greg Jones
    June 18, 2013 at 1:07 pm
    It says that driver 10.4.5 is recommended to use with the plugins, but I don’t see 10.4.5 drivers listed to download.
    Greg Jones
    D7
  • Greg Jones
    June 18, 2013 at 2:23 pm
    Nevermind. Just realized that 10.4.5 was included in the plugins. Doh.
    Greg Jones
    Greg Jones
    Orlando,Fl.
    https://www.d7-inc.com
  • Manuel Sanchez
    June 18, 2013 at 3:00 pm
    Do you get this to work?
    I have a lot of Audio Issues, when KONA Lhe+ is set to input and output for Voice Over.
    When Kona is only set to output everything works fine but I need Voice over function!?
  • Peter Garaway
    June 18, 2013 at 5:48 pm
    Hi Manuel,
    Here are some rough instructions on Standard Setup vs. Voice Over setup. We only recommend that users use ASIO or Core Audio for Voice Over ONLY! Users should switch into the Standard setup for any work being done other than voice over. This will ensure that the input and output are synched.
    Audio Setup Instructions for Mac
    For Standard Edit/Capture Setup:
    1) Set Premiere Pro>Preferences>Playback>Audio Device>AJA Device
    2) Set Edit>Preferences>Audio Hardware>Adobe Desktop Audio>Anything other than AJA Device
    3) Set Apple>System Preferences>Audio>Input>Anything other than AJA Device
    4) Set Apple>System Preferences>Audio>Output>Anything other than AJA Device
    For Voice Over Setup
    1) Set Premiere Pro>Preferences>Playback>Audio Device>Adobe Desktop Audio
    2) Set Edit>Preferences>Audio Hardware>Adobe Desktop Audio>System Default Audio Device
    3) Set Apple>System Preferences>Audio>Input>AJA Device
    4) Set Apple>System Preferences>Audio>Output>AJA Device
    Audio setup instructions for Windows:
    1) Set Edit>Preferences>Playback>Audio Device>AJA Device
    2) Set Edit>Preferences>Audio Hardware>Adobe Desktop Audio>Anything other than AJA ASIO
    1) Set Edit>Preferences>Playback>Audio Device>Adobe Desktop Audio
    2) Set Edit>Preferences>Audio Hardware>Adobe Desktop Audio>AJA ASIO
    3) Select the Audio Input for the AJA card on the AJA Control Panel
    Peter Garaway
    Adobe
    Premiere Pro
  • Manuel Sanchez
    June 18, 2013 at 6:21 pm
    Is this an usual behaviour or will this problem be fixed? In FCP Voice Over works fine!?
  • Warren Eig
    June 18, 2013 at 10:40 pm
    Also Kona 3 is supported with this update. Yeah. Need to get a Kona 3G though eventually.
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.babyboompictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
  • Steve Kallick
    November 7, 2013 at 10:39 pm
    10.4.9 available yesterday!! Seems to be working with PP7 / Kona 3 on Mac 10.8….2 systems even!! Imported XAVC HD files….they look good….audio playing better too.
