AJA-Driver.
Posted by Gregg Michaels on May 4, 2010 at 2:45 pmIs the AJA 7.5.1 driver approved for M100 1.5.1?
GM
Matt Mullen replied 16 years, 4 months ago 3 Members · 3 Replies -
Matt Mullen
May 4, 2010 at 3:28 pm7.5 is the latest qualified driver:
https://www.borisfx.com/download_files/Media_100_Suite_1_5_1_Release_Notes.pdf
Jason Tower
May 13, 2010 at 8:36 pmAny word on when AJA driver 7.5.1 will be qualified for Media 100 Suite 1.5.1?
LHe card likes to revert back to SD bars on SDI output and SD composite bars on HD component output whenever I quit Media 100. Even if I change the setting back to 1080i output in AJA Control Panel, the card always resets the next time I quit Media 100. Nothing tragic, just slightly annoying 😉
Looks like AJA fixed this in 7.5.1 as listed in “fixes and improvements”:
“Fixed a problem where the AJA Control Panel Default Video Output preference would not reset as expected or persist after a reboot (KONA LHe)”
Jason W. Tower
Fiddler Films -
Matt Mullen
May 14, 2010 at 1:08 pmIt probably won’t be until the next release.
It was briefly tested with the current release and no issues were found.
The driver will work just know that it is possible you could run into issue if you updated.
