Activity › Forums › AJA Video Systems › AJA Crashing 1080i in FCP
Jason Gillet
January 27, 2009 at 2:05 pmHi Matt,
I think the issue is with Final Cut Pro. There is some sort of Memory leak causing the problem this came from an Apple Tech I believe. It’s not a problem with the Kona Card.
Jason Gillet
Gillet Productions
Editor/Engineer -
Gary Adcock
January 27, 2009 at 5:32 pm[matt leutwyler] ” green frames show up often leading to a crash. also crashing when using compressor. Koan card, 1080i prores files, 8gb RAM, 8 quad Mac. replaced kona card.”
it is a compressor error in the conversion – this is a ProRes de-compression error.
It is best NOT to use the ProRes HQ settings when transcoding via software- you are most likely working from 8bit media and it is actually detrimental to use the HQ codec when the material is not HQ,
gary adcock
Studio37
HD & Film Consultation
Post and Production WorkflowsInside look at the IoHD
https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
