Activity Forums AJA Video Systems AJA & Blackmagic use same UC right?
  • AJA & Blackmagic use same UC right?
    Posted by Christopher S. johnson on August 10, 2007 at 11:06 pm
    The AJA and Blackmagic SD and HD Uncompressed codecs are transferable between systems, right? They are both Apple UC, right?
    I’m going to capture UC on a BM and give the drive to an AJA editor.
    Thanks.
    -Christopher
    Gary Adcock replied 19 years, 1 month ago 10 Members · 57 Replies
  • 57 Replies
  • Shane Ross
    August 10, 2007 at 11:53 pm
    No…they’re different. But all the other guy has to do is load the black-magic drivers and they will be fine. They will be able to see the footage via the Kona card.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Christopher S. johnson
    August 11, 2007 at 2:16 am
    Coolio. Thanks.
  • Sean Oneil
    August 11, 2007 at 6:55 am
    [Christopher S. Johnson] “The AJA and Blackmagic SD and HD Uncompressed codecs are transferable between systems, right? They are both Apple UC, right”
    There are Blackmagic and Kona legacy codecs from before Apple had UC natively. But you’re right. Nowadays in Final Cut, both of them just use the Apple UC codecs.
    The other guy doesn’t need to load any Blackmagic software unless it was captured w/ the BM codec – which most likely it was not.
    The only exception is 4:4:4 RGB. I believe AJA and BM still have to use their own codecs for that.
    Sean
    August 11, 2007 at 6:04 pm
    So they will play, but…
    The files I capture with Blackmagic in DV, DVCPRO-50, DVCPRO-HD, and Uncompressed SD and HD — can my client, who has an AJA Kona card, play them back and edit them with NO RT performance hit. Are the codecs exactly the same on both sides? Or are there small differences that will make green RT bars show up on an AJA?
    I need my client to not notice any difference between my captures and his — in HIS FCP timeline.
    Thanks for the clarification.
    -Christopher
  • Jeremy Garchow
    August 11, 2007 at 7:16 pm
    Both companies use the Apple codecs, except where Sean has mentioned. There’ll be no problems if you use the Apple codecs which all the cards default to these days.
  • Shane Ross
    August 12, 2007 at 3:12 am
    Then why do I hear the argument these days that Decklinks codecs are so much cleaner? IF they are all just Apple codecs….
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • John Pale
    August 12, 2007 at 4:38 am
    For regular run-of-the mill Uncompressed 8 and 10 bit (SD and HD), they all use the Apple codecs.
    The original Kona card, many years back, actually used a codec written by Blackmagic.
    Then Apple came up with RTxtreme (and Blackmagic got into the hardware business with the Decklink). AJA, Blackmagic, and Aurora eventually switched to using the Apple codecs to allow RTxtreme support on their cards.
    As Sean stated, there are also legacy codecs and 4:4:4 codecs that are not Apple supplied.
  • Jeremy Garchow
    August 12, 2007 at 3:41 pm
    WHo told you this and where’d you hear it?
  • Shane Ross
    August 12, 2007 at 4:37 pm
    It seems to be the basic argument in BlackMagics favor. Heard this around NAB…why it was used on SUPERMAN, because the codec is so CLEAN (might be getting into 4:4:4 proprietary territory here). I hear this all over the variety of forums (a while ago, and I cannot find examples, darn it) when researching what I wanted as a card. Back when I had an Aurora card…which ALSO has been told they have the best SD codec in the business (and working with it I noted how nice it was).
    This is just one of those “I heard it around…or on the streets” kind of things.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Joe Murray
    August 12, 2007 at 9:04 pm
    I read a lot of forums and have never heard anyone say Blackmagic has a quality advantage, so I guess I just missed those posts. I might expect to hear it on the Blackmagic forum but I don’t have any reason to follow that one. If you can point us to any specific threads I’d be interested to read them.
    Joe Murray
Page 1 of 6
