Activity › Forums › Panasonic Cameras › AJ-PCS060G with intel MACS
Posted by Iksoviet on June 20, 2007 at 12:09 amHi. I
Iksoviet replied 19 years, 2 months ago 3 Members · 3 Replies -
Mitch Ives
June 20, 2007 at 4:18 pmWhere does it say it doesn’t work with Intel Macs?
FWIW, it works fine with my Intel MacBook Pro. Yes, I did download the “pcdriver_macintel.zip” file and install it on the MBP.
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.comApple Certified Trainer: Final Cut Pro 5
Noah Kadner
June 20, 2007 at 6:46 pmWorks fine- make sure you’ve switched it into Mac mode.
Here’s what you’re supposed to do:
Plug in the USB cable to the Mac and the P2 Store.
Make sure the USB light lights up.
Press and hold down the Cancel button, the Battery Level indicator, and the Hard Disk Drive capacity indicator simultaneously, and hold ’em down for five seconds.The USB LED light should change color. It should go orange for Mac, and green for Windows.
