Activity Forums Panasonic Cameras AJ-HDX400
  • AJ-HDX400
    Posted by Michael Brennan on July 20, 2005 at 5:41 pm
    I’m using the AJ-HDX 400 on Friday in the UK.
    Shooting interlace, production team want a TV gamma that can be tweaked a little in post, not the full cine gamma treatment.
    Which gamma or other settings should I use?
    Are the menue and gamma functions similar to Varicam?
    cheers
    Mike Brennan
    Michael Brennan replied 21 years, 2 months ago 2 Members · 2 Replies
  • Steve Mahrer
    July 20, 2005 at 6:18 pm
    Hello Mike:
    The AJ-HDX400 features some Cine-Gamma modes, but these do not include the “FILM REC” mode of the VariCam. The 400 uses a menu structure much like the SDX900, as such it’s “Film-Like” modes look great, plently of control over master gamma, the knee, colourimtery, detail etc. With these you should be capable of building a very nice look, if required, even quite filmic. You should be able to get quite close to the desired look “in camera”, then just fine-finish in post.
    Good shooting,
    Steve Mahrer (Panasonic Broadcast)
  • Michael Brennan
    July 20, 2005 at 10:17 pm
    Thanks Steve.
    I’ll refer to SDX900 references rather than the Varicam film rec
    Sounds straight forward.
    Look forward to using the combination of 12bit AD and 4:2:2!
    best
    Mike Brennan
