Activity Forums Panasonic Cameras AJ-HD1200 Jump on EE video
  • AJ-HD1200 Jump on EE video
    Posted by Michael Peele on June 29, 2006 at 1:50 am
    Aloha,
    I have a AJ-HD1200 deck connected via FW from my G5.
    In EE mode on the deck, video from FCP jumps on the external monitors (both the SD Composite monitor w/ overlay & HD-SDI monitor). We will soon be in EE mode all the time when editing and the jumping is going to drive me crazy.
    This is a known issue apparently (see menu item 031 – OUT REF) and affects only the output, not what is laid to tape.
    Is there a known solution?
    Does anyone else experience this issue as well?
    A previous post in here related the issue to timing discrepancies between the FW port on the G5 and the deck (the deck being more precise than the G5). Any idea if a nice FW PCI card would resolve the issue?
    If there is no setting or sync generators, my only thought is that I would need a HD-SDI card for my G5. What is the favored card for this type of application? The AJA KonaLHe (It has DVCPROHD acceleration)?
    Should I post this in the FCP room?
    Thanks for any suggestions!
    Mike Peele
    Chris Bell replied 20 years, 2 months ago 2 Members · 1 Reply
  • Chris Bell
    June 29, 2006 at 4:43 am
    There is no solution. I added a Black Magic card to my edit system, and view HD via the component output.
    I don’t know if Panasonic found a work around in the new deck.
    Chris Bell, Seattle
