Activity Forums Panasonic Cameras AJ 1200a Issues
  • AJ 1200a Issues
    Posted by Ryan Risley on April 14, 2006 at 8:37 pm
    I just finished a shoot using the Varicam and am having a deck/capture issue with the 1200a.
    I can capture from the deck to the computer fine. But, when I record back to the deck (final output), I cannot re-capture what i just recorded to the deck. i know the deck captured it, because i can monitor it, but Premiere isn’t seeing the recorded data. If I pop in any other tape that was recorded on by the camera, it shows instantly. This concerns me if I ever need to re-import a finished project for re-purposing. Is there a mode on the deck that I must switch? I don’t believe it to be a software issue and I didn’t have any extra tapes to try (in case i had a faulty tape). Does anyone have any insight into this?
    My comp is a hardcore, custom built PC (insert heckle here) running the decklink HD Pro card and Adobe suite.
    Thanks in advance,
    Riz
    Ryan Risley replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
