Airplay, FCPX, and Premiere working surprisingly well
Set up Mountain Lion tonight on my Late 2011 Macbook Pro. Played footage full screen in Premiere and FCPX (also with QT using the native AVCHD decode). Both AVCHD native and ProRes played close to perfect out to the Apple TV (720P model). Only once was there some stuttering that went away after a few seconds.
Picture and audio fidelity were great. I was playing 24P footage and there was no hint of flicker or weird interlace issues. All was well. This was all going HDMI out to a Denon receiver out to a Panasonic 50″ Plasma.
I’m very impressed. I can see using this in the future, especially as the tech gets better. Amazing to be sitting in the living room with my laptop cutting wirelessly in HD to my TV (ok ok, there was *one* wire involved – a FW 800 cable!).
There seems to be between 1-3 frames offset between the laptop display and the TV. Also there was some minor sluggishness in the UI while editing, but that seemed to go away.
My TV at home is calibrated to the best that I could calibrate it. Did some basic three-way cc. No way of knowing yet how spot on the colors are, but I suspect it’s getting compressed all along the way. Probably good enough for web stuff, definitely good enough for a personal project. Anyway, I’m just geeking out and having a good time with this. Hope the info helps someone with something, sometime or somewhere ;D.
Michael Garber
5th Wall – a post production company
