Activity Forums Apple Final Cut Pro Legacy Airbox compatible mpg2 transport stream from FCP?
  • Airbox compatible mpg2 transport stream from FCP?
    Posted by Nils on November 17, 2005 at 11:36 am
    I work in a community TV station and we are having trouble getting Compressor to make a Transport Stream MPG2 that our PC based Airbox play system will accept. It reports an error with the audio.
    We are currently exporting out of FCP with compressor using the default Mpeg2 setting with TS checkbox ticked to interleave audio and video.
    Any ideas, what about squeeze, bitvice, mpegstreamclip??
    FCP 5.0.3
    Dual 2.7GHZ G5
    PAL 48khz
    Sydney, Australia
    Nils replied 20 years, 10 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    November 17, 2005 at 3:19 pm
    What kind of audio does it want is the question?
    MPEG streamclip is free, and I have had nothing but good luck with this handy and free utility. DId I mention it’s free?
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
  • Michael Alberts
    November 17, 2005 at 4:15 pm
    You might try BitVice Helper to mux the audio into a transport stream.
    Michael Alberts
    Ambidextrous Productions, Inc.
  • Nils
    November 22, 2005 at 12:29 pm
    Thanks for your advice.
    FYI: Both Mpeg Streamclip and Bitvice Helper solved our problem. Muxing in compressor creates a ‘transport stream’. This caused problems on the Airbox component of Playbox. Muxing in Bitvice Helper creates a ‘program stream’ which works fine.
    Nils
    Sydney, Australia
