Activity › Forums › Apple Final Cut Pro Legacy › aiff to mp3
aiff to mp3
Posted by Colin Spencer on June 2, 2005 at 5:15 pmHow do I convert my audio files into mp3 files so I can e-mail them.
thanks!colin
Josh Rambo replied 12 years, 4 months ago 5 Members · 6 Replies -
Thaxter Clavemarlton
June 2, 2005 at 5:23 pmUse iTunes.
I do this all the time.itunes (menu) > Prerences… > Importing > “Import Using:” > MP3 Encoder “Setting:” > (choose “High” or “Higher” for best quality) > “OK” (closes preferences).
Drop your AIFF clip into an iTunes open window, click once on your clip to select it, and choose:
Advanced (menu) > Convert Selection to AIFF.Works VERY fast and stores new MP3 file in the iTunes library.
You can do a “search” (apple f) to locate the new MP3 file on the hard drive and then just drop it into an email.
June 2, 2005 at 5:26 pmThere as a small error in the previous post:
It should be “Convert Selection to MP3” (not AIFF as I posted earlier).The full, corrected method is as follows:
iTunes (menu) > Prerences… > Importing > “Import Using:” > MP3 Encoder “Setting:” > (choose “High” or “Higher” for best quality) > “OK” (closes preferences).
Advanced (menu) > Convert Selection to MP3.Works VERY fast and stores new MP3 file in the iTunes library.
Chris Poisson
June 2, 2005 at 5:46 pmHey Thax,
This is good to know, not real savvy with iTunes. How do you get a hold of the files, drag them out of the iTunes library?
BTW, as a side benefit, Compression Master 3 makes great mp3s, fast!
Jeff Carpenter
June 2, 2005 at 5:51 pmHow do you get a hold of the files, drag them out of the iTunes library?
===Just grab it right there from the library and drag it to any folder (or the desktop). It will make a copy of it wherever you drop it.
Josh Rambo
May 7, 2014 at 11:21 amI agree with Thax.
But if you want to batch convert AIFF files to MP3, iTunes is not able to help. iTunes only supports batch converting AIFF to AAC, not MP3.
Here is a guide about how to batch convert AIFF to MP3
