Activity Forums Compression Techniques AIFF or AC3 ?
  • AIFF or AC3 ?
    Posted by Fredy Schwerdtner on December 6, 2010 at 10:50 pm
    I’m doing a DVD job which the client wants the best audio quality. I use Apple Compressor. Is it ok using MPEG2 for video and let the audio uncompressed as AIFF ?
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    4GB 667 MHz DDR2 SDRAM
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.6.4
    Final Cut Studio “3”
    Craig Seeman replied 15 years, 9 months ago 3 Members · 4 Replies
  • Craig Seeman
    December 6, 2010 at 11:03 pm
    The problem is that AIFF files can be large enough to force a lower data rate for the video. Also I hear some DVD players have problems with AIFF files.
  • Fredy Schwerdtner
    December 6, 2010 at 11:20 pm
    “AIFF files can be large enough to force a lower data rate for the video”
    I’ve heard that once …..
    Thanks.
    MacBook Pro 17″
    OS X 10.6.4
  • Jason Brown
    December 6, 2010 at 11:35 pm
    I’m pretty sure that aiff isn’t a supported audio codec for the DVD specification. Any authoring program will transcode aiff to PCM or dolby digital (ac3) format.
    Dolby digital is pretty universal. It has a very low bit rate while maintaining high quality. Unless you have a need for PCM, I’d use ac3.
  • Craig Seeman
    December 7, 2010 at 12:12 am
    https://en.wikipedia.org/wiki/Audio_Interchange_File_Format
    The audio data in a standard AIFF file is uncompressed pulse-code modulation (PCM).
    iDVD uses PCM for example.
    https://en.wikipedia.org/wiki/DVD#DVD-Video
    and/or LPCM Stereophonic
