Activity › Forums › Adobe After Effects › AI Roughen equivalent in AE?
Posted by Wyclef Chron on December 3, 2014 at 3:58 pmHey, what’s the AE equivalent to AI’s Roughen… CS6? Is there one?
Ken Teutsch replied 11 years, 9 months ago 3 Members · 6 Replies -
Daniel Waldron
December 3, 2014 at 6:38 pmWhat does the AI Roughen effect do exactly? The Roughen Edges effect in After Effects may be what you are looking for.
Wyclef Chron
December 3, 2014 at 6:58 pmyou can use it to make a circle like… not a perfect circle with some organic quality to the path.
Ken Teutsch
December 3, 2014 at 9:09 pmIf you are working on a shape layer, you can add a “wiggle paths” to the circle. That will let you “roughen” up the circle and also let you animate it.
Wyclef Chron
December 5, 2014 at 4:53 pmI found Roughen Edges under Effects > Stylize…. but where can I find Wiggle Paths?
Daniel Waldron
December 5, 2014 at 5:03 pmWiggle Paths is not under Effects. It can only be used with shape layers. If you have a shape layer, twirl it open in your layer panel and you’ll see an “Add” button above the blend mode. Select that and a whole list of attributes including Wiggle Paths will appear.
If you want to apply it to text, you can convert your text to a shape layer by going to Layer -> Create Shapes from Text.
Ken Teutsch
December 5, 2014 at 5:11 pm
