Activity Forums Adobe Illustrator AI object with alpha
  • AI object with alpha
    Posted by Scott59 on July 31, 2007 at 8:37 pm
    I’m very new to Illustrator. How do I export an object I have drawn in Illustrator, bring into after effects but key out the background for animation in AE.
    Vincent Rosati replied 19 years, 1 month ago 2 Members · 1 Reply
  • Vincent Rosati
    August 2, 2007 at 9:02 pm
    You can import the AI file into After Effects, than drop it into a layer.
    If you have a closed path that outlines you subject in the Illustrator file you can use that as a layer mask in After Effects. Just copy the path in AI, than select the layer in AE and paste.
    Do you need a mask, or could you just delete the unwanted parts from the AI file?
