Activity Forums Adobe After Effects AI into AE distortion
  • AI into AE distortion
    Posted by Jeaster on November 15, 2006 at 11:16 am
    When I import .AI files into AE they are the same height but the width is squashed and generally, the quality of the strokes is poor.
    Why is this?
    I built the file in Illustrator on a document 720×576 and am using the same size composition in AE on PAL DV Widescreen preset.
    Thanks, James.
    Jeaster replied 19 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jim Kanter
    November 15, 2006 at 5:29 pm
    The reason is that DV uses non-square pixels and AI uses square pixels.
    Which version of each app are you using?
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Jeaster
    November 15, 2006 at 8:20 pm
    After Effects 7
    and
    Illustrator CS2.
    “The reason is that DV uses non-square pixels and AI uses square pixels”
    Any idea what I should do to work around this?
  • Jeaster
    November 15, 2006 at 8:38 pm
    I went to Interpret Footage and changed the Pixel Aspect Ratio from ‘Square Pixels’ to ‘D1/DV PAL Widescreen’ and this has allowed the file to maintain its original dimesions but the lines still look somewhat ‘pixelated’. Any ideas?
  • Derrick
    November 16, 2006 at 4:27 am
    Hi there,
    Turn on continuously rasterize, right between the shy-hide layer, and quality button to the right of the Source Name column, you’ll see a switch that looks like a ball with spikes. turn that on.
    – Derrick
  • Jeaster
    November 16, 2006 at 10:11 am
    Thanks. This has made the whole image clearer but the lines are still pixelated. They almost seem like they are dashed.
  • Derrick
    November 16, 2006 at 8:59 pm
    Are you working in draft or full quality?
    – Derrick
  • Jeaster
    November 18, 2006 at 8:52 pm
    Full resolution and full quality
