Activity Forums Maxon Cinema 4D AI CS4 to Cinema 4D
  • AI CS4 to Cinema 4D
    Posted by Chris Walter on April 16, 2009 at 2:08 am
    I have a really simple illustrator document with a logo on it. I just need it in Cinema 4D. When i tried it before i only got a gray colored plane. Is there any way to get rid of the background of the document in illustrator, becuase that seems to be my biggest issue. Thanks for all the help!
    Chris Walter replied 17 years, 5 months ago 2 Members · 4 Replies
  • Brian Jones
    April 16, 2009 at 3:20 am
    The Illustrator was saved as version 8? Only splines come into C4D not fills or backgrounds.
  • Chris Walter
    April 16, 2009 at 10:16 am
    I apologize, i am not an Illustrator User, i’m more of a Photoshop person. So is whatever image i have loaded in Illustrator already a spline? IF not, how do i make it one?
  • Brian Jones
    April 16, 2009 at 6:14 pm
    The only way to do it really well is to do the splines in Illustrator yourself (using the image as a guide), unless you can find a vector version of your logo somewhere. Otherwise, you could use Live Trace (I read it better than the old Trace tool) in Illustrator but the results are not likely going to be good enough to look good in C4D once you extrude it.
  • Chris Walter
    April 17, 2009 at 12:56 am
    Hmmm….okay that’s gonna be a tough one, but I guess i’ll try doing the spline myself. Thanks for all the help!
