Activity › Forums › Adobe Illustrator › AI CS > v.9
  • AI CS > v.9
    Posted by Stu Denbigh on July 8, 2005 at 4:09 pm
    HI –
    I have created an Illustrator CS document which contains brush strokes only.
    Is there any way to open this (preferably with layers) in an older version of Illustraor – I’ve tried saving as an eps, but it doesn’t work.
    Any help appreciated.
    s
    t
    u
    Lazlo Hollyfeld replied 21 years, 2 months ago 2 Members · 1 Reply
  • Lazlo Hollyfeld
    July 8, 2005 at 4:24 pm
    You should expand the brush strokes into basic shapes before saving it for an earlier version. I think it is in the “Object” menu at the top. Once expanded, the brush stroke is not “procedural” so to speak, and that is what makes it incompatible with earlier versions. Saving as an EPS will work fine as long as the objects are expanded.
    Arie
