Activity Forums Adobe After Effects Aharon’s jumbotron
  • Aharon’s jumbotron
    Posted by Cody Campbell on October 22, 2008 at 7:09 pm
    In Aharon’s Jumbotron tutorial, he splits the rgb of a layer by triplicating it and removing two of the three colors on each copy. Isn’t there an easier way to do this? Like a plugin that puts it all in one spot? Andrew Kramer’s twitch splits rgb but only in a chaotic fashion.
    Essentially what I would like to do is link rgb split to depth with an expression so that the furthur away an object is the greater the rgb split is. I’ve already done the expression with other plugs and it works great. I just need a better way to split rgb.
    _Cody
    “Just because noone understands you does not make you an artist”
    Cody Campbell replied 17 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
