Activity › Forums › Adobe After Effects › Aharon Rabinowitzs’ animation tutorial problem
  • Aharon Rabinowitzs’ animation tutorial problem
    Posted by Rafael Lopes on June 5, 2006 at 1:53 pm
    I’m working on a 45 minutes narrative project that has already been shot and now needs to “cartoonized”. I checked Aharon Rabinowitzs’ tutorial that uses after effects and ilustrator and I found it amazing, specialy with all different variations that can be done. Well, I followed all Aharons’ intructions very closely and did exactly what the tutorial said, but the problem is that I have 61 thousand images to be processed/vectorized. Opening adobes’ bridge takes a while (a tried exporting cache and some other options and it kind of gives me litlle bit of extra speed). But the real problem is that I can select all images but it never gets passed a thousand images. And this is making my work insanely hard, since I have to select the first thousand images and then click on “live trace”, then I have to select the next thousand images and click on “live trace again”. It took me a day in front of the pc to do 10 thousand images. And according to the tutorial I SHOULD be able to process all images with no problem. I changed the code values that needed to be changed (to 99999), which should give me about 50 minutes of video, but the issue persists. Any advice?
    P.S – I also posted this topic on the illustrator forum. I don’t really know if there’s any problem if I post it here too, since it has to do with both applications. I contacted Aharon Rabinowitz and he told me to post it here because it would be easier to get some answers.
    Rafael Lopes replied 20 years, 3 months ago 2 Members · 2 Replies
  • Aharon Rabinowitz
    June 6, 2006 at 4:13 am
    Liek I said in my email, try doing less images at a time. Yeah, it should work with all images at once, but it’s probably overtaxing your machine. Try breaking them up. Noboday said this proecess would go quickly.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Rafael Lopes
    June 6, 2006 at 7:29 am
    Thanks for the help anyway. For the last 10 days that’s all I’ve been doing. I’m almost finished with the first layer (54 thousand images done out of 61 thousand). I figure it’ll take me about a month to finish all layers. It’s an excruciating process but it’s looking amazing so far.
