Activity › Forums › Adobe After Effects › Aharon Rabinowitz video opener
Posted by Mark Fogarty on March 19, 2006 at 2:46 pmI really like the look of colour changing/flashing lines and squares that you see at the beginning of Aharon Rabinowitz’s video tutorials. I’m fairly new to AE but I assume there must be a fairly easy way to create such a look. Can you point me in a direction. Thanks in advance.
Aharon Rabinowitz replied 20 years, 6 months ago 4 Members · 4 Replies -
Tim Klink
March 19, 2006 at 4:46 pmis it only his one, because it is also in the podcast of andrew kramer, I don’t know, but I would try fractal noise.
The things you own end up owning you.
Aharon Rabinowitz
March 19, 2006 at 4:53 pmSure – I used Fractal noise to create the blocks (Noise type). I played with different properties, such as the Fractla noise’s transform to make it long lines.
Also, I lowered the complexity as low as it would go, so it would just be simple squares or rectangles)
I also animated the evolution.
Finally I used a different transfer mode for the effect, other then normal – it might have been screen or overlay.
The fractal noise effect is possibly the most robust effect in AE, so you should definately play around with it – especially in conjunction with other effects such as colorama, for example.
Hope this helps.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Chris Zwar
March 19, 2006 at 8:24 pmFractal Noise is indeed very useful- the following article will take you through the plug-in:
https://www.creativecow.net/articles/zwar_chris/fractal_noise/index.html
There’s a Part 2 which is coming soon…
-Chris
Motion Graphics Designer
Will animate for food -
Aharon Rabinowitz
March 19, 2006 at 8:40 pmSounds great. I use Fractal noise very often, becasue it can do so much. Your tutorial on the science of it was excellent. Thanks.
Aharon
Aharon Rabinowitz
