Activity Forums Avid Media Composer AHA!!! moment…
  • AHA!!! moment…
    Posted by Roman Mykytyn on June 28, 2005 at 3:59 am
    Hey,
    Just a little FYI for those of you troubleshoot Avid problems (which is probably all of you). I was having EDL trouble recently (see previous post) and Avid Tech Support couldn’t fix it, instead recommending I uninstall, then re-install,…
    Anyway, having just set up my new XpressPro 4.6, I hadn’t gotten around to turning off the Energy Saver (OSX 10.3.8). Each time I booted up the Avid, I got a message stating, “Don’t let the drives sleep, you idiot.” Even though I never left the machine unattended long enough for sleeping to interfere, I guess the mere threat of this freaked out the Avid, because as soon as I disabled it, my troubles with the EDL manager pretty much went away.
    So, the next time a friend calls for advice on a weird issue, ask him/her to make sure the Energy Saver has been set to “NEVER.”
    Maybe this is obvious, but it wasn’t to me.
    Roman Mykytyn replied 21 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
