Activity Forums Sony Cameras AGC and limiter for audio
  • AGC and limiter for audio
    Posted by Jim Stamos on March 11, 2012 at 9:49 am
    i shoot alot of events and noticed tonight that some of my audio seemed too hot. should i have my AGC set to High or Low and what does the limiter do? i have to On.
    will having it set to High cause what happened?input welcome
    Dean Longfield replied 14 years, 5 months ago 5 Members · 22 Replies
  • 22 Replies
  • Don Greening
    March 11, 2012 at 11:34 pm
    You haven’t provided much information about what you’re recording and if you’re using line level input (from a house mixing board) or mic level from a radio transmitter or a hard wired mic. I think you might be talking about mic level but I’ll touch on line level just in case.
    If it’s from a mixing board here’s some recommendations. First of all, a professional mixing board’s peak signal is +10dBu whereas your EX peaks at -12dBu. Most audio people round off the -12dBu peak signal from a video camera to -10dBu and refer to this as the “ten+ten” rule. As you can see, there’s a huge difference in signal strength between the two. Setting your camera’s inputs to line level will solve the mismatch in most cases but in others it’s simply not enough to knock the board’s signal down for the camera to deal with. If the signal coming from the board is distorting, no amount of camera gain lowering will fix it because the signal is too much for the camera’s pre amp. The solution for this is to purchase one or two inline adjustable attenuators like the ones at the link below:
    https://www.audio-technica.com/cms/electronics/a05620466ab0ce16/index.html
    These plug in to the XLR cables the mixing console has sent to you then in turn plug into yours before the camera. You can adjust them to minus 30dBu in 10dBu increments.
    If you’re requesting advice about mic level signals then I invite you to read the recommendations at this link:
    https://forums.creativecow.net/readpost/142/878123
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Jim Stamos
    March 12, 2012 at 3:41 am
    don, i was shooting a wedding reception as i have many times before.
    i had my agc on high and my limiter on . is there any audio software that can improve this audio? all my dance footage at the reception sounds hot.has to be something to improve it to a level that bride wont notice
  • Jim Stamos
    maybe i should keep the audio on agc low from now or go with a small shotgun. someone suggested the rode nt5.
  • Don Greening
    March 12, 2012 at 4:57 am
    Whatever mic you were using to record the loud music was too sensitive (too hot) for the job. The signal was over-driving the camera’s pre-amp and that’s why you got the distortion. You can try trimming the signal in the menu but I suspect you’ll still get distortion even at a quiet volume and with AGC active. To solve the issue you need to get a mic that’s much less sensitive. Since I don’t record loud music I can’t advise you on what to buy. for example, a good shotgun for recording the spoken word is not going to do a good job of recording loud music.
    You also can’t fix digital audio in post once it’s distorted. Digital audio turns into hash as soon as distortion happens, whereas analogue audio is more forgiving and can be manipulated somewhat.
    – Don
    Don Greening
    Reeltime Videoworks
  • Bob Mark
    March 12, 2012 at 3:41 pm
    All very true. That’s why you need to monitor the camera audio with very good set of headphones that will let you know if the audio is too hot. Relying on the meters alone is suicide.
    Bob
  • Dean Longfield
    March 12, 2012 at 4:30 pm
    I have an EX1R and have been slowly testing it in the field. On events with loud music I have found the same problem that Jim had. I tried using both the built in mic as well as two shotguns. All I did to adjust the audio was to put the Audi-In setting on Manual and adjust the levels. That does not cut it on the EX1R. Others here on the Cow have suggested that I lower the Trim Level, which is what I’ll try next. (Ext Mic Input, Manual Audio, and bring the trim down). I’m thinking of bringing it down to the -32 or so range and adjust from there. I’m also going to try switching the high/low setting on the AGC, but am hoping that the low is not too muffled. I’m not sure about the gain setting but I initially am planning on leaving it on ‘0’ and taking it from there. This time I’m bringing an attenuator as well,
    just in case all in camera methods are not providing suitable results.
    Re: Mics: I made the mistake of using a Sennheiser ME-66 indoors with very amplified (LOUD) sound. Not a good combo. Then I used the mic from the old DSR cameras (300/500 series) and that wasn’t really much better.
    So I’m going to purchase the Sony recommended mic: the Sony ECM-673/9x Shotgun mic.
    It’s an Electret Condensor and has a Super cardiod pick up pattern, (just like the DSR mics).
    AND am going to experiment with setting the levels as described above.
    There has to be a workable combo of mic choice and audio settings. It’s just a matter of finding it.
    With the EX1R, I’ve been recording sets that are not critical to the edit, so if they don’t come out well I
    don’t use them, (I use other cameras, that I’m used to, for the critical footage).
    When I find the right combo, (that works for me), I’ll report back.
    Good luck.
  • Bob Mark
    March 12, 2012 at 5:05 pm
    The problem you are experiencing comes from using microphones that do not have a high enough SPL (sound pressure level) rating. Many shotgun microphones have this problem. The ME66 is well know for this overload issue. The Sony shotgun you mentioned does not have a better SPL rating than the ME66. They are both around 125 db SPL. Some mics like the Shure SM81 (not a shotgun) have a built in pad that will take the SPL up to 146 db. AKG makes some nice mics for music recording as well. Shotguns are designed to reach for sound, so that comes into play too. Is there any place you can rent some mics to test? Good luck.
    Bob
  • Brent Dunn
    March 12, 2012 at 7:04 pm
    The limiter will limit the amount of audio, keeping some of the peaking levels to a set level. Compressor’s can also squeeze the audio.
    For receptions, I use the automatic gain, since the audio is all over the place and I don’t have any silent spaces where my gain will boost. It’s worked very well for me and I don’t have to worry about distortion. I use a wireless either plugged into the board or a handheld mic on a stand in front of the speaker, as well as an on camera mic for the 2nd track of audio. For better audio, you may want to invest in a Zoom H4N recorder.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
  • Jim Stamos
    March 13, 2012 at 6:21 am
    i never had a problem with this issue with my dsr300 and i shot 100s of receptions.
    is the recommended mic for the ex1r going to be as bad as the oncam mic? would hate to throw money and time away if it wont do the trick
  • Bob Mark
    March 13, 2012 at 5:12 pm
    It all comes down to how well the microphone handles loud sound levels (SPL). If the mic is clipping you are a dead duck. No amount of mixer or camera audio adjustment will save you.
    Bob
Page 1 of 3
