AFX Renders dodgy wav’s
After effects is rendering dodgy wav’s that are really making my work difficult, the problem is a lot of professional audio software will reject wav renders from AFX because the wavs have no chunk length, it’s easy to check, it’s the number right after ‘RIFF’ at the beginning.
This means that every wav I render (Which is every clip I work with at the moment) has to be first exported to another piece of software that doesn’t check for these errors so as to then re render each wav with the correct chunk size encoded in to it.
I know other audio functions in AFX are terrible, this is why I have to do all my audio work in another app in the first place, but AFX seems to be hindering my work even then!
I need a solution here, I can’t keep doing this, my audio is having to be processed by 3 different apps now and it’s taking forever.
This is no user error on my part, this is a bug, plain and simple!
