Activity › Forums › Adobe After Effects › AFX not showing immediate changes
  • AFX not showing immediate changes
    Posted by Adam Duplay on September 19, 2011 at 11:56 pm
    I must have changed something inadvertently…
    Now when I adjust a parameter I don’t see the change as I am moving the mouse, only when I stop moving.
    For example… make a new mask then use the mouse to adjust the mask expansion parameter. It used to be the case that I could see immediate feedback and see the mask outline change as I adjust the slider. Now the change only becomes apparent when I let go of the mouse. The same issue is affection all parameters… position, scale, etc.
    Thanks in advance.
    Adam Duplay
    Adam Duplay replied 15 years ago 3 Members · 3 Replies
