Activity › Forums › Adobe After Effects › AFX CS6 Rendering 17000X15000
  • AFX CS6 Rendering 17000X15000
    Posted by Gon Perdigao on February 13, 2013 at 10:15 pm
    Hi there,
    Im rendering a file that is 17000X15000 for print, and i’m using videocopilot lens flares and looks and trapcode plug ins.
    I can work perfectly, but i can’t render full quality, without AFX stoping working.
    What is the best method to export just one Still image?
    I have a PC with 30GB of memory, i7 with 12 threats and with 3 hard drives of 1T.
    Thanks a lot
    Chris Brett replied 13 years, 7 months ago 2 Members · 1 Reply
  • Chris Brett
    February 14, 2013 at 8:57 am
    — easy one …
    1 ) scrub through timeline to select frame you want to print
    2 ) slide the left hand ( yellow ) timeline selector up to the time line marker
    3 ) slide the right hand selector right up to the time line marker ie whee the selected frame is — this will give the frame you want with selection markers either side.
    4 ) send to render queue
    5 ) before printing make sure to deselect ‘fields’ and also consider whether motion blur needs to be ‘on’ or ‘off’.
    6 ) render out as usual
    ————– all the best ——chris —
