Activity Forums Adobe After Effects AfX CS3 Effects Glitch
  • AfX CS3 Effects Glitch
    Posted by Tyler Yowell on September 2, 2008 at 3:37 am
    Running CS3 Pro. Premium on XP SP3, I’ve noticed that whenever I add effects to a composition, the effects randomly cut off and back on, sometimes with the entire layer disappearing. This happens regardless of the effect I’m using and project I have open. Thank you for your help!
    Geforce 6100SM Motherboard w/Athlon 64 X2 3600+ and 2GB DDR2 RAM
    Tyler Yowell replied 17 years, 12 months ago 2 Members · 4 Replies
  • Kevin Camp
    September 2, 2008 at 4:04 am
    is it just in the preview window or in the final render?
    if it is the preview window, do you have opengl enabled? if so, try disable it (preferences>preivews, uncheck the opngl option and set preview acceleration to adaptive resolution)… opengl is flakey in ae.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Tyler Yowell
    September 2, 2008 at 5:01 am
    No OpenGL supported-the problem is present in previews, exports, and renders.
  • Kevin Camp
    September 2, 2008 at 5:11 am
    hmmm, how about multiprocessing? have you tried enabling/disabling it to see if there is any effect?
    have you tried edit>purge>all to see if that has any effect?
    you might also try rebooting… it sounds kind of simple, but i find it often helps when ae is behaving in unexplainable ways…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Tyler Yowell
    September 2, 2008 at 12:17 pm
    Tried all of the above with no results…
