Activity Forums Adobe After Effects AFX Composition not linked in Media Encoder
  • AFX Composition not linked in Media Encoder
    Posted by Kathie Andersen on December 9, 2014 at 8:50 pm
    One of the After Effects Compositions that I have in a sequence is not linked when I import the sequence into Media Encoder.
    The After Effects Composition is linked in Premiere Pro. But when I import the sequence to Media Encoder, it is no longer linked.
    Any ideas? Thank you!
    Kathie
    Tim Kurkoski replied 11 years, 8 months ago 2 Members · 3 Replies
  • Tim Kurkoski
    December 10, 2014 at 2:04 am
    Does the behavior change if you do either of the following?
    1. Save the After Effects project, then close and re-add the sequence to AME.
    2. Disable Import Sequences Natively in AME’s preferences > General, then re-add the sequence to AME.
  • Kathie Andersen
    December 10, 2014 at 2:22 am
    Thank you – but I do not see any difference when I try the two things you suggested. AFX Composition which is actually a title is not linked once imported in AME even though it is linked in PPRO.
  • Tim Kurkoski
    December 10, 2014 at 8:56 pm
    OK, need more information then.
    When you say “not linked”, what do you mean? What is the result that you’re expecting, and what is the result that you’re actually getting?
    Screenshots of what you see in Premiere Pro and what you see in AME would be helpful.
