Activity Forums Avid Media Composer AfterEffects to Avid workflow
  • AfterEffects to Avid workflow
    Posted by Greg Quitiquit on May 6, 2008 at 2:18 am
    Hi. New Avid user here, but I’m a longtime AfterEffects user. I have some pieces that I’ve created in AE that I want to take into Avid. Using the Avid Meridien codec, I get the message that says “Quick Import” while importing, but the import is no where near what I would think is quick, considering I’ve used their codec. I’ve tried dragging and dropping and I’ve tried using the “import” dialog. Am I missing something?
    Jeff Greenberg replied 18 years, 4 months ago 3 Members · 4 Replies
  • Jon Zanone
    May 6, 2008 at 11:41 am
    I use the animation codec exclusively. It comes in pretty quick – I’m usually importing :30 seconds in less than 2 minutes.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Greg Quitiquit
    May 6, 2008 at 2:37 pm
    I’m curious why you don’t use one of the Avid codecs? It would seem to me that would be the fastest way, since (I assume) it would involve no re-encoding.
    Greg Quitiquit
  • Jon Zanone
    May 7, 2008 at 2:21 am
    I’ve found it great for going to different systems, and I’ve found it gives me the cleanest video.
    Jon
  • Jeff Greenberg
    May 25, 2008 at 5:12 am
    If you have it configured right (in AE’s export), The ‘fast import’ should be 1.25 RT or so.
    Meridian uncompressed, Millions of Colors +, STRAIGHT Alpha, lower field first, 720×486.
    Best,
    Jeff G
    Principal Instructor
    Future Media Concepts
    FMCTraining.com
    Editorsretreat.com
